Dual Stage Clutch....JD 1050
Tweeter
04-27-2008 06:55:08
I need to replace the clutch in my 1050. The PTO clutch seems fine, though I will be replacing that clutch disk also while I am in there. I never fooled with a dual stage clutch before. My plan is to replace the tranny clutch disk, pto clutch disk, pressure plate, bearings. Are there two pressure plates or one? I do not really understand the JDPARTS illustration.
YTMAG offers a: (Clutch Kit - Tru-Power Clutch kit. DUAL CLUTCH. Contains NEW : Clutch 9in. pressure plate assy (19 spline-36mm 6-pad), Heavy-duty 9in. disc (13 spline-25mm hub, woven disc) release bearing, pilot bearing. Fits: 850, 870 (sn 016000 & up), 900HC (wyanmar diesel), 970, 1050, 1070. (Part No: AM878710K)).
If I buy a new pressure plate, do I have to do all the adjustments or is everything preset?
Edpap
04-27-2008 08:04:59
 Re: Dual Stage Clutch....JD 1050 in reply to Tweeter, 04-27-2008 06:55:08
Hello,
The clutchs that i sell are pre set. I would think that the JD sell are preset as well. there are some reman clutchs out there that are not set and you could run into trouble. the clutch will come with the trans disc in the pressure plate assembly and the PTO disk loose. your fly wheel should have a .020 flywheel step. this is not as important on you tractor because the PTO disk rides on the flywheel the trans disk works on PPA that will be all new. you can look up the parts on my web site. i have a heavy duty clutch for around $750 and a standard clutch for for around $713 all bearings included. that is a heavy clutch so I would say the frt would be around $30.
Good Luck Ed
