7300 John Deere won't go into gear
tractordoc
04-26-2008 21:54:06
have a 7300 2-wd that won"t go into gear, when i shift the power shift it changes engine RPM"s but no movement, i can shift the A-B-C-D shifter in and out of gears with out the clutch being pushed and the powershifter is in a gear. it use to be if i shifted to fast i had to shut tractor off shift into park and re-start and it was fine. also the clutch pedal use to dangle, and we was driving it that way for quite a while, then my hired hand kicked the clutch pedal and it popped back up and seems to work but that is when it stopped going into gear, it looks like the linkage is moving in the valve in the bottom. I also am not getting the gear read out on the dash now don"t know if that has anything to do with it.
powertech84
04-28-2008 17:59:41
 Re: 7300 John Deere won't go into gear in reply to tractordoc, 04-26-2008 21:54:06
kinda sound like the roll pin sheared. check to make sure were the clutch pedal cable connects that the shaft is actually turning and not just the outside
tractordoc
04-27-2008 15:59:53
 Re: 7800 John Deere won't go into gear in reply to tractordoc, 04-26-2008 21:54:06
it is a 7800
mattd
04-27-2008 13:48:05
deere never made a 7300 tractor. did you mean 7400? i dont understand how your clutch pedal could be dangling, if it was the tractor wouldnt be moving. did the clutch spring break? check your system pressure. a long time ago there was a pip out on the shifter cables. make sure there is no mud build up around the cables on the right side of trans. have you deere dealer check the adjustment as there is special tools needed to do this.
tractordoc
04-27-2008 15:58:42
 Re: 7300 John Deere won't go into gear in reply to mattd, 04-27-2008 13:48:05
well i messed up, it is a 7800, doesn't appear to have mud build up and the clutch spring is fine, but the clutch pedal felt loose and didn't work such as stopping the tractor when pushed. then when it was kicked it felt like it should but that is when it the tractor quit moving, i have removed spring and worked lever down below by hand and all seems to move
