 Finally got started putting 70 gas back together. Head is done, block was bored out and new pistons and rings, crankshaft was turned for new main bearings. Ordered new gaskets for everything. So I started putting the crankshaft in this afternoon, and no gasket for left ( crank side) bearing housing. Know I ordered it when I ordered the one for the right side. Either it didn't come in or it's misplaced. I put all the gaskets together when they came, so I don't think I lost it, but I've been wrong before. My question, if I can find some gasket material, could I make one that would work? If I order another one Monday, it will be here Wednesday, rather not wait that long, Like to get as much done as I can while it's too wet to get in the field. I thought about blue silicon, but there is a oil passage in the bearing case that would probably fill up and then no oil could get to bearing. The gasket for the right side main bearing is paper thin, is there something I could use to make a gasket for the left side? Open to suggestions, thanks in advance, Chris
