7020 starting problems
df
04-26-2008 17:44:33
I have a 1972 7020 w/ the 404ci eng. When it has been sitting a day or so and you crank it, it will run about 2 sec. and knock off. When you try to restart it take a while for it to finally crank unless you use Either. I have ordered a fuel transfer pump. I am thinking that the pump is leaking back and loosing pressure to the filter, therefore starving the inj. pump for fuel. Am I on the right tract anyone?
wayne_co
04-27-2008 05:20:31
 Re: 7020 starting problems in reply to df, 04-26-2008 17:44:33
You can put a check valve before the filter. It won't cost much and should also fix most leak back. You also should put another spin-on filter with a bigger micron rating if your having any problems with plugged fuel filters. This is a good place to put a check plus it will stop most of the junk before it gets to the final filter.
Bob
04-26-2008 20:36:48
I just dealt with one a few days ago that had the fuel pickup tube in the LH tank cracked.
Are there any visible signs of leakage at the IP or the fuel filter that will "weep" diesel while rrunning, and admit air after shutdown?
df
04-27-2008 06:00:01
 Re: 7020 starting problems in reply to Bob, 04-26-2008 20:36:48
I have not noticed any leakage.
