730D brake release
mike a
04-26-2008 14:40:31
Any of you know where I can order those aftermarket brake pedal release things so you don't have to bend over and shut your wind off every time you want to release the brakes. I think they're some sort of spring loaded affair
mike a
04-28-2008 12:52:05
 Re: 730D brake release in reply to mike a, 04-26-2008 14:40:31
Thanks a bunch!!!! I'll put my mind to work and rig up somtin'
Mike M
04-27-2008 05:39:03
My 720 has pins welded to the side of the floor pan this keeps the latches from falling down as far makeing them harder to reach. I used a pair of the old car spring wire type door panel retainers and just clipped them on my 50 for the same results with no permenant alterations.
RobMD
04-26-2008 15:58:52
Not spring loaded. They just have weight hanging off the back end so that when you press in on the brake, the release falls down and you're in business. I have seen people add weight to the back of the release bracket AND add a piece of rod sticking stright up so that you may lock the brakes without cutting your wind off, too.
