2020 brakes
novot 67
04-26-2008 07:56:05
the brakes do not work separately, when i press right pedal both wheels stop and the same with left. Any suggestions ?
buickanddeere
04-27-2008 14:58:49
 Re: 2020 brakes in reply to novot 67, 04-26-2008 07:56:05
There is a spring loaded ball used in the equalizing circuit inside the brake cylinder. Your tractor's problem maybe a stuck open ball/seat.
GeorgiaHayFarmer
04-26-2008 19:31:46
Are both brake pivot shafts rusted together somewhere?
Scott
novot 67
04-27-2008 03:39:05
 Re: 2020 brakes in reply to GeorgiaHayFarmer, 04-26-2008 19:31:46
when the pedals are pressed both pistons operate independently. There has to be some sort of valve in the housing that is clogged or stuck sending fluid to both wheels.
JMS/.MN
04-26-2008 11:27:31
Look for a mechanical link locking both pedals together. Flip it over the other way.
novot 67
04-26-2008 16:19:54
 Re: 2020 brakes in reply to JMS/.MN, 04-26-2008 11:27:31
the link is not engaged, the brakes just seem to operate as one when pressing one pedal at a time.
