6600 Cylinder head locators
harpoonlouis
04-26-2008 06:20:14
Is it OK to ask about a 6600 here? Not sure if that qualifies as a classic?
If it is ok, here is my question. If not I apologise.
I am re-fitting a cylinder head on a 6600 tractor and am puzzled. The head has been skimmed 15 thou, the block is standard. When we lowered the head on to the two locating dowels fixed into the face of the block there is about an 1/8 of an inch free movement! I can see the front dowel through the water jacket and the is a gap right around the dowel and looks like something is missing. If the water system was open to this dowel I would have expected to see some corrosion or staining on it but it looks perfect, like it was not in contact with the water circuit at all.
Anyone know how this head locates on these dowels?
Did we loose an insert in the machine shop?
Thanks to anyone who can help.
F-I-T
04-26-2008 14:32:30
 Re: 6600 Cylinder head locators in reply to harpoonlouis, 04-26-2008 06:20:14
If you don't have a parts book for it, you might want to go to JDPARTS, and use the model search to bring up the 6600 parts book. I have not had a 6600 engine apart, but there is a dowel pin called out for the block deck in 2 places, and there is also a bushing used in two places. I can't say if they work in tandem, but I wonder if one of those two items is the mate that you might be missing. I saw the dowels and the bushings in two different cylinder block illustrations. I tried to mark up a composite view.
I hope this helps.
Frank
third party image
harpoonlouis
04-27-2008 08:46:23
 Re: 6600 Cylinder head locators in reply to F-I-T, 04-26-2008 14:32:30
Thanks Frank, will look at those parts and see if I can get an assembly drawing Monday.
