How do 6 volt systems work on 40 Series JD
Bruce Lamarre
04-26-2008 05:50:42
I have a 1942 JD 40 crawler tractor. The battery keeps going dead. The manual says it is a positive ground system. When I bought it it was hooked up as negative ground. I replace the generator and polarized it with it grounded negative.
How should it be grounded?
How do I polarize the generator?
What are the likely causes for the battery not chargeing?
garytomaszewski
04-26-2008 17:34:13
 Re: How do 6 volt systems work on 40 Series JD in reply to Bruce Lamarre, 04-26-2008 05:50:42
If you are sure the generator is good and the Regulator is for a NEGATIVE ground just touch the battery and armature connections to make a spark. Battery won't charge if Reg. is bad, if ammeter is bad, if there isn't a complete cicuit, if the battery is bad,
Bruce Lamarre
04-26-2008 19:10:06
 Re: How do 6 volt systems work on 40 Series JD in reply to garytomaszewski, 04-26-2008 17:34:13
How do I know if the regulator is for a positive or negative ground?
