3010 is missing
david gunther
04-25-2008 20:33:34
hi guys i have a 3010 that is missing. changed the points on it checked the plugs and it has good spark. ne ideas?
Roy Suomi
04-25-2008 21:23:04
 Re: 3010 is missing in reply to david gunther, 04-25-2008 20:33:34
put a new set of plugs in it..preferably not Champions..I use Autolite or Motorcraft..They have a better tendency of not flooding out..You can find the dead cylinder by feeling the exhaust manifold when it's cold..After starting the engine , quickly touch the manifold ports where they come right out of the cylinder..The misfiring cylinder will be noticeably cooler than the firing cylinders..
RobMD
04-25-2008 20:48:18
Warped valves, leaky piston rings. To check, do a compression test. Just because a plug makes spark doesn't mean anything. Should be a bright, consistent, blue spark. You might have a carburetor problem as well, might not be vaporizing consistently.
