4320 Brakes
Sonny JD
04-25-2008 18:01:55
I have a 4320 tractor and the brakes were just replaced, but when I apply the brakes the pedals go down half way and then lock up the brakes and then pedal kickes back up. It does the same thing on both pedals. I'm not sure whats causing this.
Sonny JD
04-25-2008 18:25:27
 Re: 4320 Brakes in reply to Sonny JD, 04-25-2008 18:01:55
I Opened up ftg on tubing going into rear end and bleed some off on right brake, but it did'nt seem to help. Let me know how you bleed them.
rexhellwig
04-25-2008 18:51:09
 Re: 4320 Brakes in reply to Sonny JD, 04-25-2008 18:25:27
Oops! I meant to post that message to you, Sonny.
Not myself!
rexhellwig
04-25-2008 18:18:45
Call whoever did the brakes and ask them why they didn't bleed them.
If they're not willing to do it, post back and we can walk you through the procedure.
rexhellwig
04-25-2008 18:45:04
 Re: 4320 Brakes in reply to rexhellwig, 04-25-2008 18:18:45
OK. First, make sure the trans oil is full. This is important. Low oil levels will foam the oil in the hydraulic system. The "power" for the power brakes comes from the main hydraulic pump. It's pretty safe to assume that if the power steering is working OK, then the system should be good enough to furnish oil to the brake valves.
The only tools you need are a 1/2 inch and a 5/8 inch combination wrenches. There are two special fittings designed especially for bleeding the brakes. They are located {one on each side} just above each axle housing. {Close to where you opened up the brake oil line} The bleed fittings look like bolt heads with jam nuts sticking our from the differential case.
You'll need an assistant. Run the engine 1000 rpm or so in park. Loosen the bleeder screw jam nut on the LH side of the tractor and loosen the bleeder screw about 1/2 turn. Have your assistant hold the LH pedal down for about 60 seconds. When the time is up, keep holding down on the pedal and tighten the bleeder screw. The pedal will force your buddy's foot up. Now you can tighten the jam nut. Repeat this procedure for the RH side with the RH pedal.
This should do it.
