4010 won't run
Rudy in TX
04-25-2008 17:29:57
I am needing advice. My 4010 diesel slowly died as I was using it the other day. I pulled it to the house and changed fuel filters. It would start and the slowly die again. I put a new fuel pump on it and it does the same, runs for a little while(20 secs.) and dies. If you pull the throttle down while it is running it blows a plume of whitish smoke out the exhaust and runs terrible. Injector pump was rebuilt about 300 hrs ago but did not check the injectors. Please let me know what ya'll think happened. Thanks, Rudy
Big 3010
04-29-2008 13:14:07
 Re: 4010 won't run in reply to Rudy in TX, 04-25-2008 17:29:57
By the way you describe the engine running and then slowly dying it sounds like classic symptoms of a plugged return line. I have had the same problem with my 3010 diesel before. Take the return line out of the tank, still keeping it attached to the nozzles, and stick it in a bucket and start the engine. If no fuel runs out into the bucket before the engine dies then you know for sure you have a plugged return line.
jjamna
04-27-2008 05:57:37
Check the return line
Regan
04-26-2008 06:26:10
Sounds like maybe the return line to the tank is plugged. I had a 3010 do the same thing, a fly crawled up inside the line from the tank!
S.C.
04-25-2008 22:32:03
Open the drain on the bottom of the fuel tank and check for water.
msb
04-25-2008 18:29:38
Remove the fuel line to the lift pump coming from the tank and see if you have a full flow of fuel. Sounds like the line may be plugged.
