Did I Mess UP ( head gasket)Power Block
Ben.So.Tex
04-25-2008 05:02:50
I did a head job on my G awhile back, and now when I crank it it spits/sprays water from the exhaust. I retourgh it a 2nd time when the engine was hot. My G has a Power Block, I put the head gasket that it calls for from JD.. But I am thinking that Maybe the Power Block take a different head gasket. Need some input. Thanks Ben
J Chantry
04-25-2008 09:25:24
 Re: Did I Mess UP ( head gasket)Power Block in reply to Ben.So.Tex, 04-25-2008 05:02:50
Ben
I have a 49A with a power block. I had the same problem you describe. Turns out one of the cylinder o-rings was leaking coolant. Very hard to replace o-ring because the cylinder is a wet sleeve. Ended up putting new head gasket (standard JD A head gasket is the correct one) then using Barr's liquid glass head gasket sealer. It has been worked hard for last 1 1/2 years with no leaks!
Earl -IL
04-25-2008 07:25:39
Ben, Make sure the manifold studs aren't seeping into the cylinders . After it sits take the plugs out & crank over to narrow it down to #1 or 2 Cyl.
2 Cylinder
04-25-2008 05:50:12
Drew has it right, use Deere head gasket and follow his instructions.
Mike M
04-25-2008 05:21:02
I too am also wondering if the sleeve o-rings of that power block are leaking ?
Resting Relics 1
04-25-2008 05:19:56
Ben, I'm pretty sure you can't use a Deere head gasket on a power block. Power blocks were built by others and a much bigger bore than a standard G block. I don't know where you can get the right gasket but I'm sure someone here knows and will post. John
Drew
04-25-2008 05:17:49
The stock headgasket is what you need.
Unfortunately, I think you may other problems. Was the head surfaced when you had it worked on? Is the deck on the power block flat? If either of those surfaces are not flat, all the torque in the world will not make it seal. If both of those surfaces are flat, then either the block or the head may have a crack, or possibly the top O-ring on the power block sleeve could be leaking. Is there any water/antifreeze in the oil?
Ben.So.Tex
04-25-2008 09:11:10
 Re: Did I Mess UP ( head gasket)Power Block in reply to Drew, 04-25-2008 05:17:49
No anti freeze in the oil...The head was resurfaced, but not the block it stayed in the tractor. Thanks to all for the replys, I am not in the mood to pull it down and out at this point but will have to before something happen.
Later Ben
Drew
04-25-2008 16:09:37
 Re: Did I Mess UP ( head gasket)Power Block in reply to Ben.So.Tex, 04-25-2008 09:11:10
Did you have this same block and head in this tractor before you took the head off? I assume the manifold was off the head when it was at the machine shop??
If both of those are a YES, I would look into what Earl is saying about the manifold studs before I took the whole thing apart.
Good Luck!!
