24 to 12 volt on 4020
Doug in IL
04-24-2008 19:29:43
I switched my older 4020 over to a 12 volt system yesterday. It starts ok, but I have a few other problems. The fender lights don't work. The charging indicator lite doesn't lite up when the key is turned on. And the fuel gauge acts like its working backwards. I followed the instructions that came with the changeover kit. However, there's no mention of these accessories in the instructions. All these things worked fine before I started the job. Anyone have any help for me? I'd sure appreciate it.
4020 chuck
04-24-2008 22:41:37
 Re: 24 to 12 volt on 4020 in reply to Doug in IL, 04-24-2008 19:29:43
You may need to change out your sending unit also. Just converted mine last summer an there is a 12 volt positive ground sending unit you will need.Let us know how it goes.
Good luck,
Chuck
msb
04-24-2008 19:34:32
You will have to get a negative ground fuel gauge. The circuit breakers on the back side of the kick plate will have to be inner connected with a jumper wire
