4640 wheel adjustment
Moline_guy
04-24-2008 17:20:22
Trying to move the wheels in on a 4640 to 30". Got the wedges loose, but gear drive is rusted solid and heating is not doing the trick. Question: can i just cut that gear out of there and cinch down the wedges and keyway and be good to go? I am guessing that gear does not do anything except to adjust the wheel, thanks for any replies.
Moline_guy
04-25-2008 04:49:35
 Re: 4640 wheel adjustment in reply to Moline_guy, 04-24-2008 17:20:22
Thanks for the replies, we have the wedges out and wheel into position, will try heat and oil another time, and pushing the pin out if not i think the gear is going to get cut out so we dont' need to mess with it next time. Thanks again, other wheel prabably going to be the same fun.
RobMD
04-24-2008 19:00:03
Spray it with kroil first, then heat it again and melt wax into the thing. Smack a boxed end wrench down witha 2 pound hammer up and down on the pinion screw. It'll come, eventually.
M w J
04-24-2008 18:27:24
Mine on a 4640 was stuck and I did get them loose .They were filled up with dirt around the gear also If you take the wedge out with the key in you can turn the gear side to the bottem and blow it out with air. That pinion shaft should lossen up if you find a shaft just a little smaller the hole and smack it back and forth . If it don't come loose the wheel can be moved on the axel with the Key wedge out Mike
rexhellwig
04-24-2008 18:20:42
Don't expect to get 30". If I remember right, 32" is about as close as you get.
If the wedges are loose, you have already tackled the hard part. Turn the wheel so that the pinion shaft is vertical. You can really get the penetrating oil down deep with this trick, especially when using heat. This should work. But let's assume the worst. If you remove the wedge opposite the pinion gear, The wheel can be lifted free of the rack teeth. {forklift or tire cart needed}
I don't think you can torch the gear out of the way.
mattd
04-24-2008 18:11:13
the shaft is rusted to the wheel. some times working it back and forth sometimes will loosen it up but ive done it this way many times. use an air hammer and punch it out. it goes out on the hex side so use an air hammer on the opposite side of the hex. the gear is pressed to the shaft so it will take a little to get it out. but the gear will stay in there and cause probelms tryin to move the wheel. if you can get a wheel cart use it to support the wheel. remove the wedges completely. then clean it all up and reinstall without the gear.
mike cerciello
04-24-2008 17:33:36
Yes you can, but if you can try spraying the pinion gear down with a GOOD grade of penetrating oil, let it soak for a while then use an impact gun on the pinion gear hex haed it self an d let it hammer it in both directions. iI have had this same problem with my tractor and this trick worked. I also had worked the tractor with the wedge bolts completely removed for five years before the wedges broke loose. When they finally let go it sounded like a 30.06 springfield going off. Good Luck
Mike Cerciello
[email protected]
