JD 2440 timing
kevin ullman
04-24-2008 12:51:07
Friend of mine just had the injector pump rebuilt,new injectors installed on a 2440 John Deere,now it is really hard starting below 50 degrees air temp.He has to plug in the block heater for an hour to get it to start.started easier before all the new parts were installed.Can anyone tell me what the correct timing is for this unit ? Guy that installed it says the timing is good.I want to double check it.Any tips or ideas would be appreciated.Thanks
Edpap
04-24-2008 19:53:00
 Re: JD 2440 timing in reply to kevin ullman, 04-24-2008 12:51:07
Hello Kevin,
The timming is top dead center #1 cyl and the lines on pump under the window are lined up. it sounds like you to far advanced. there is a hole in the flywheel to locate DTC thru the bell housing. you could try turning the pump alittle on a cold day and see if it starts if not go the other way. if you go too far the engine will smoke. do not move the pump with engine running.
Good luck Ed
kevin ullman
04-24-2008 23:45:13
 Re: JD 2440 timing in reply to Edpap, 04-24-2008 19:53:00
thanks for the info,we will check it out and post what we find.
