3point wont work
dgp
04-24-2008 10:09:13
on my 2010 the 3pt just stopped working, after removing seat, with mtr running there is a foutian of oil that shoots out of top plate by the levers inside by the lift arms.
GeorgiaHayFarmer
04-24-2008 17:30:35
 Re: 3point wont work in reply to dgp, 04-24-2008 10:09:13
Sounds like the little adjuster that sits back there got away from ya. It is a threaded rod with a nut on it that is meant to lock it down at the proper setting. If you go to JDPARTS and go to the parts catalog on the left hand side of the page, click on it and at the top left type in 2010. You then should be able to open up a 2010 parts catalog. When you find the back of the tractor in the catalog, you should see that little adjuster thread, I'm referring to. If you have any other questions just ask. What year 2010 do you have? I am working on a 1961 diesel right now and am almost finished tinkering with it. A very expensive tractor to work on.
Scott
