Identify JD part
David from Kans
04-24-2008 08:46:47
I would like help identifying a JD part #P125H. I don't have a pic but will try to describe it. It is a round iron weight, about 12-14" in diameter, about 4" thick, with about a 2 or 2-1/2" hole thru it. The hole thru the center is smooth, but has a set screw that goes thru from the outside at an angle. Didn't some old pull type combines have a counter-balance on the header to help with lifting? Any help appreciated.
Mark Scholten
04-24-2008 14:39:31
 Re: Identify JD part in reply to David from Kansas, 04-24-2008 08:46:47
My master parts list says part number P125H subs to P1020H and part description is combine.
David from Kansas
04-24-2008 21:20:38
 Re: Identify JD part in reply to Mark Scholten, 04-24-2008 14:39:31
Thanks Mark. That makes me think it is a counter-balance weight.
