6410 Hyd pressure light
Torqnut
04-23-2008 19:47:43
My hyd pressure light is coming on intermittently on this tractor. The "stop engine" light comes on at the same time. Oil levels are all good - tractor acts normal.
A sensor problem? Something I can do/replace - or have to go to dealer ?
powertech84
04-24-2008 16:51:01
 Re: 6410 Hyd pressure light in reply to Torqnut, 04-23-2008 19:47:43
yeah, its very common for these sensors to go bad. its on the front of the engine about 3/4 of the way up. the original one is about a 1 3/16 nut, and the new one is a 9/16. easies way i've found is to get that one line out of the way, and then use a hammer to bust the plastic part of the old sensor off, then its easy.
Torqnut
04-24-2008 06:28:02
Yes - and Yes.
Just came from the dealer actually - full service done.
Torqnut
04-24-2008 06:29:17
 Re: 6410 Hyd pressure light in reply to Torqnut, 04-24-2008 06:28:02
Has anyone changed out the trans/hyd pressure sensor themselves? Wondering if I can manage this myself - or if it's a dealer item.
Thanks for the insight.
Old Bob
04-24-2008 07:45:42
 Re: 6410 Hyd pressure light in reply to Torqnut, 04-24-2008 06:29:17
I looked at these sensors when I was having a problem with mine and they are exposed on the outside of the tractor. They are located right in front of the transmission, if my memoery serves me right, its been 5 years since I owned that tractor. The only problem with changing them from what I could remember, is that it takes a special wrench or tool to do this.
Old Bob
04-24-2008 05:44:38
I had a 6410, these lights came on all the time. Dealer said it was the sensors, they changed them, it was still under warranty. No more problems. Have since traded it for a 6420.
MSM
04-24-2008 01:49:37
Changed the hydraulic filter lately,fluid full?
