520 Ignition switch
Tbolt76
04-23-2008 19:40:25
John T and all I was browsing some posts you made for people having ignition trouble with different tractors, one being a 520. I was having trouble with mine cutting out, and someone I know told me to change the ignition switch. I could wiggle it and make it cut out, so it made sense. I swapped the switch, but the new one only has six terminals, the original had 7. I did my best to keep all the wires marked, but now it won't start. I have lights, but I'm wondering if disconnecting the oil gauge could have triggered the "low oil" function and caused it to not start. Any suggestions as to mixing up some of the wires going to the switch. Thanks. tom
buickanddeere
04-24-2008 06:14:45
 Re: 520 Ignition switch in reply to Tbolt76, 04-23-2008 19:40:25
Somebody may have also sold you a similar looking switch for a 6V diesel or the different again switch for a 24V diesel.
DeereValley
04-24-2008 05:31:20
The switch should be part number AA5397R. Some of them have the MAG post and some of them don't. The MAG post should have a brown wire that goes to the positive post of the coil. When I make new wiring harnesses for our own tractors, I do not even make this wire.
The main wire that feeds the coil is a black one that goes from the IGN post to the resistor. The other side of the resistor (green) goes to the negative side of the coil. (There should also be another black wire that goes to the starter switch on this side of the resistor.)
One other thing, that is not ignition related but has given us trouble before on one of our 520s and 630s, is the low pressure shutoff. The rubber can stick to the shutoff part and will not allow gas to flow. The valve stem will still move, but with out the rubber piece.
Hope this helps.
John T
04-24-2008 05:14:31
TB, Those switches can get confusing as some switches had the MAG or GND terminal my old friend ET mentioned which was connected to ground when OFF to kill a Mag and/or ground the coils output so she couldnt fire when cranking due to the starter switch by pass function. Stick a volt meter or test lamp on the coils high (NOT to distributor) terminal n see if voltage appears when you turn the switch ON????? ?? If not shes not wired correct. Is a terminal labeled IGN ?? thats the one that wires to a ballAst (if it has one) and then wires to teh coils input. Also if it has the Mag or GND termianl that needs to wire to the low (to distributor) coil terminal to kill the spark when the starter is cranking but if its miswired you may be always grounding out the coil?? A test lamp on the switch terminals with everything disconnected except the hot BAT input should show you whats what..... I also wonder as posted below if its the right switch cuz they made the switch for the pony start diesels also which looks similar....
The coils not gonna fire until it has a hot input and its output wires to the distributir and IS NOT grounded out exepct for the closing of the points
John T
Mike M
04-24-2008 04:39:48
KEEP YOUR OLD SWITCH 9 out of 10 of them can be easily taken apart and cleaned up and put back together. If the posts are loose you can restake them or even make new ones from the copper split rivets for dog tags.
ET
04-24-2008 03:47:37
I think the origonal switch had a ground terminal on it that may have been there if a magneto was used. It's not on the replacment switch.
Tbolt76
04-24-2008 04:14:14
 Re: 520 Ignition switch in reply to ET, 04-24-2008 03:47:37
This tractor has a distributor on it, and I think the extra terminal might have something to do with the lights. There is a little coil spring that connects two terminals marked "HL", but the new switch just has a single post in this spot that connects to two spots via a brass bar.
ET
04-24-2008 04:30:08
 Re: 520 Ignition switch in reply to Tbolt76, 04-24-2008 04:14:14
That little coil was a resistor that gave you low beams on the lights. Are you sure you have the right switch?
Tbolt76
04-24-2008 18:41:43
 Re: 520 Ignition switch in reply to ET, 04-24-2008 04:30:08
ET, Deere Valley, John T, Thank you for the suggestions. I will try them tomorrow 4/25. The guy I bought the switch from restores JD's and he had a few similar suggestions, i.e. check coil, etc. He mentioned that this tractor has a positive ground. However, I'm not sure how this works exactly compared to negative ground equipment that I'm used to. My battery is negatively grounded, but that's how I assumed I should install it not knowing otherwise. There was an unmarked terminal on the old switch that I'm wondering now if it is a ground terminal. I also still have the ballast resistor. Is this resistor Deere specific or would any auto type one do? Luckily I labeled all wires as I took them off, so retracing my steps shouldn't be too difficult. Thanks again guys and I'll report back to HQ later.... I'd like to sit in on some of your workshops and the "wearin of the green" next year. Tom
