Correct seat for a1940 B
Gary from Mules
04-23-2008 18:17:52
My 1940 B has a 16 hole smaller seat on it. Is this the correct seat for this tractor? I have seen some at shows with the 9 hole seat. I am just curious what the factory seat is suppose to be. I know the un-styled B had a 24 hole small seat on them.
PBrowning
04-23-2008 20:31:03
 Re: Correct seat for a1940 B in reply to Gary from Muleshoe, 04-23-2008 18:17:52
An Excerpt from the John Deere "H" Restoration Guide, 3rd Edition - - - (PatB)
THE SEAT -- Owners of early styled JD tractors often debate the number of holes are to be found in the AD1606R pan seat for a given production year tractor. According to reliable sources, this seat was used on all styled tractors equipped with a pan seat, but the number of holes changed over time! From the beginning in 1939, until some time in late 1941 production, the seat had 9 holes. Then it was changed to a 7-hole pattern that held through most of 1944 production. Beginning with 1945 you should expect to see 5 holes. It appears a 3-hole decision was implemented by late 1946, and continued into 1947 when this seat was phased out. See three-holed seat pictured at chapter�s end. AD1606R is still available from Deere, and it comes with ZERO holes! During the Un-styled tractor era, seats had far more than 9 holes. �Interesting to observe!
