Cooling System
Blaz
04-23-2008 11:43:51
Just wanted to find out if anyone could help me out. Our farm has a JD 1070 we originally had a coolant leak I have had the radiator bored and installed a new rad. cap (over the years and a few bottles of stop leak it needed to be cleaned out). The temp gauge was working before all this went down. Today I installed a new thermostat because the bottom radiator hose did not seem to be getting hot like the top one. Still no reading on the temp. gauge, any ideas before I have JD repair come out and spend the money on a service call. I have thought the only other things could be the water pump, a fuse ( note the gas gauge works) or just a bad connection. I kinda need to figure this out because one of my helpers yesterday said a light came on on the int. panel and the engine shut down after letting it set 20 minutes it started. Any advice would be of great help. Note I have not seen any coolant leaks since installing the rebuilt radiator.
RobMD
04-23-2008 21:28:09
 Re: Cooling System in reply to Blaz, 04-23-2008 11:43:51
Did you install the thermostat the right side up?
I know on my 770, that if the temperature guage doesn't work, NONEEE of the other gauges/lights work.
i also know that if it's not working hard, the temp gauge will not come up for a long time until after you start working it in the field.
