Bars Oil Oil Leak
JD Gimpl
04-22-2008 22:12:01
I Have a 46 B that has an oil leak behind the flywheel and was wondering if anyone has used this product.
if you have did it work?
Thx Gimpl
Vern H
04-23-2008 19:24:48
 Re: Bars Oil Oil Leak in reply to JD Gimpl, 04-22-2008 22:12:01
Who sells the seal only? I haven`t had any luck finding it. Thanks. VH
F-I-T
04-24-2008 08:58:59
 Re: Bars Oil Oil Leak in reply to Vern H, 04-23-2008 19:24:48
It's on the page for the flywheel. Depending on the parts installed, it's either item #1 or #2. The cork type seal is easier to install if you soak it in motor oil for a bit first.
Frank
third party image
JD Gimpl
05-08-2008 18:55:37
 Re: Bars Oil Oil Leak in reply to F-I-T, 04-24-2008 08:58:59
Hi FIT
This looks to be for a 1950 B. Is it the same for a 46?
Thanks a bunch, Gimpl
Vern H
04-24-2008 09:33:37
F-I-T
Thanks for the response. I am looking for a source to buy the seal only. All I have found is a whole engine rebuild gasket set which I don`t need. Thanks, VH
F-I-T
04-24-2008 10:31:23
 Re: Bars Oil Oil Leak in reply to Vern H, 04-24-2008 09:33:37
Greg Stevens parts page shows the B130R as available. You can e-mail him for that part at [email protected]
The other seal, the inner rubber on for "B"s using the spacer is B3028R and is about $%.00 at your Deere dealer.
Vern H
04-24-2008 11:46:46
 Re: Bars Oil Oil Leak in reply to F-I-T, 04-24-2008 10:31:23
F-I-T Thanks for the info. VH
F-I-T
04-24-2008 10:32:00
Meant to say the B3028R is around five bucks at your dealer.
Bob
04-23-2008 07:46:39
Oil leak stop products work by causing old, hard, brittle rubber seals to soften and swell. There is NO rubber seal in there, so there's nothing for the product to "fix".
There's a mechanical labyrinth seal (oil slinger) in there, with a cork washer sealing it so oil can't get through BETWEEN the slinger and the crankshaft.
greenday
04-23-2008 04:32:01
If you have a leak behind the flywheel that means the little cork spacer gasket on the oil slinger is bad. You're best bet is to replace the seal and know it is fixed right! About $20.00 in parts to repair.
