720 LP
WV Ike
04-22-2008 21:18:16
Got a 720 LP that will idle but shuts off as soon as you hit the throttle. It will start to wind up but dies. Runs great at an idle.
Ben.So.Tex
04-23-2008 12:55:58
 Re: 720 LP in reply to WV Ike, 04-22-2008 21:18:16
Make sure air cleaner is fill with oil, check to see that a mud dobber has not closed the vent hole in the regulator, Last you may want to adjust the jet that lay parrallel between the two barrel's, on top of the carb it has a roll pin in it.
