730 Power Steering
Grabatire
04-22-2008 20:45:36
The power steering on my 730 operates a bit weird. When turning the steering wheel in either direction it starts to go easy, then seems to hit a hard spot. It continues the rest of the way but real slow. It doesn't matter how slow or fast I begin the turn, or much effort is applied to the wheel, it won't turn any faster. It feels as though there is something resisting the effort to turn the wheel.
However, if when it hits the hard spot and the steering wheel is moved quickly in the opposite direction then back in the direction of the turn, it will go through the remainder of the turn as fast as I can turn the wheel. When it gets to the end of the turn, the same thing happens going back the other way.
The oil level is right up too.
Any suggestions?
Grabatire
04-23-2008 06:57:47
 Re: 730 Power Steering in reply to Grabatire, 04-22-2008 20:45:36
Thanks Mike M. I'm glad its something I can remedy in house. Coming up with the service manual will probably be more challenging.
Mike M
04-23-2008 08:08:21
 Re: 730 Power Steering in reply to Grabatire, 04-23-2008 06:57:47
you can order them right from JD with a credit card.
Mike M
04-23-2008 04:39:20
You have problems in the valve and actuating sleeve. This is a very common spot to have wear and broken edges of the worn gear where the pins ride in. You can rework ,deburr and readjust everything and likely get it back working smooth again. Make sure you get a copy of the factory JD service manual made just for these steering units !
