Countershaft Idler Gear Spacer
njs
04-22-2008 09:09:54
The Spacer between the idler gear and the 2nd and 5th gear is pictured with the larger O.D. against the idler gear. I know mine was reversed when I took it apart. Can it be facing either direction?
Thanks,
Mike M
04-22-2008 09:38:41
 Re: Countershaft Idler Gear Spacer in reply to njs, 04-22-2008 09:09:54
What are you working on ? Some of the service manuals tell what goes which way. If we find out what you have maybe we can look it up.
njs
04-22-2008 10:26:24
 Re: Countershaft Idler Gear Spacer in reply to Mike M, 04-22-2008 09:38:41
Sorry Mike,
'50 A s/n 667....
Picture in the manual shows this Spacer with Lg O.D. to the right--up against the C'shaft Idler Gear. Mine was opposite AND prvious owner recalls some 2nd gear issues---. Does it matter which way it is placed?
Jeff
Mike M
04-22-2008 10:55:27
 Re: Countershaft Idler Gear Spacer in reply to njs, 04-22-2008 10:26:24
Are you looking in a genuine JD parts manual ? If this is what you are looking at I'd go by the picture as I have found them to be very accurate.Plus given previous owner stating of problems with that gear. Some of those spacers that go in next to the idler gear are made to fit over a snap ring or would have to be sized to fit tight next to it. If one end is larger than the other than it must be made to go in a certain way for a reason. I don't have an A service manual other than an I & T and I don't think Deere ever made one. I think they may of made one for a 60 which would have alot of the same gears in it. Call your local dealer and see if they happen to have one laying around, if they are an old dealer. I too would also be worried about putting this in right, as you are. Have you tried a trial assembly of all the gears and spacers on the work bench to see how it all fits and if it can indeed go either way without binding up ?
Kurt_JDB
04-22-2008 14:39:43
 Re: Countershaft Idler Gear Spacer in reply to Mike M, 04-22-2008 10:55:27
Mike,
I just looked at the parts book on the JDparts website, and the large end of the spacer in question is very clearly adjacent to the idler gear. I think he would be safe reinstalling that way.
I really think it is neat that all these old parts manuals are available over the web. Now if they would just do the same with all the service manuals....
Kurt
