401C Loader Problem
J. David
04-22-2008 08:39:33
My 1982 401C with the industrial (1 lever) loader locks up and won't curl back up when the boom is extended and the bucket is fully opened. It acts as if the bucket becomes "overextended" and seems to be a mechanincal issue rather than a hydraulic one. I am able to remedy the situation by lowering the extended bucket over a pipe rail fence and backing the tractor causing the bucket to "curl back up", but i don't want the issue to re-occur. Has anyone else experienced this type of problem?
Edpap
04-22-2008 21:21:52
 Re: 401C Loader Problem in reply to J. David, 04-22-2008 08:39:33
Hello J david, you might not have the right bucket for that loader or you pins are worn enough to let the bucket go to far. you need to put some stops on your bucket they should be under the lower bucket pins. it might of had them and they are broken or worn.
Good luck Ed
