730 Pony - - - - - - -IT RUNS!
Grabatire
04-21-2008 22:26:33
Well I rigged up a cooling system and after cleaning the carb, changing the oil, installing new points, condensors and coils I fired up the pony while it was sitting on the bench. Good lord that thing sure knows how to get a fellow interested in some ear plugs.
It started right away and ran good, but for an engine that has very close to top compression (98 to 108) it sure does smoke a lot. I hope it's because it hasn't ran for quite some time. Oh well, spring will be here real soon and it will make good mosquito control.
Thanks to those who responded to my post last fall and changed my mind about converting to electric start. In this part of the planet a pony will work much better.
WeirdDeere
04-21-2008 23:06:39
 Re: 730 Pony - - - - - - -IT RUNS! in reply to Grabatire, 04-21-2008 22:26:33
I'm glad to hear it's running. Yep, they can be surprisingly noisy for such a small engine!
The smoke MIGHT go away after some good running, but if it is like most ponies (that haven't been totally rebuilt)...it will keep smoking to some degree or another. The valve guides are probably worn...and the oil drain back holes in the heads might be partially plugged. Both of these make lots-O-smoke. Not a real problem...just keep an eye on the oil level.
Brandon
