.045 over aluminum pistos
jdhbag
04-21-2008 18:08:17
I have a used set of .045 aluminum pistons for a late model B and need the skirt clearance for the rebore. The new ones I put in my A required minimum of .010 clearance. Thanks in advance for any information on this.
gtx1967jewison
04-27-2008 19:59:20
 Re: .045 over aluminum pistos in reply to jdhbag, 04-21-2008 18:08:17
any machinist worth paying measures the pistons INDIVIDUALLY 1ST, then bores each hole to fit each piston correctly according to specified clearance from original service manual. no 2 are the same, or 8 in a car.
Mike M
04-22-2008 09:47:05
That same .010" figure sounds about right for alum. pistons. As I though cast ones were .005-.006" ? Take your standard bore dia. 4 11/16 then add .045" record this figure. Then measure the pistons and they should be made enough smaller to fit right in. See if it doesn't come up to close to .010"
jdhbag
04-22-2008 10:18:48
 Re: .045 over aluminum pistos in reply to Mike M, 04-22-2008 09:47:05
Thanks Mike. I was thinking along those same lines. Just wanted some assurance.
Mike M
04-22-2008 10:58:42
 Re: .045 over aluminum pistos in reply to jdhbag, 04-22-2008 10:18:48
So far every piston I ever had that was marked with the oversize was sized to fit just fine at that much over standard bore. But you do want to double check all this stuff as someone can throw you a curve ball.
