A couple of question about a 1947 A
Kirk-NJ
04-21-2008 17:44:08
I'm going to look at a 1947 JD A.The wheels are set out to 7 1/2' I would like to move them in so it might fit on my trailer or I will have to pay to have it moved. What size wrench will I need? Any tips to get it off? Should I try some heat? Once I get the bolts off you can use those bolts to move the spine? What size tap should I get in case of rust/crap in the bolt holes? 3/4 10 tap? what it the hight of the rear so I bring the proper jack with me.
Thanks, Kirk
James Howell
04-21-2008 19:28:41
 Re: A couple of question about a 1947 A in reply to Kirk-NJ, 04-21-2008 17:44:08
You might consider renting a trailer with no rails.
Moving wheels on a tractor away from your shop and your tools could be a real challenge.
RobMD
04-21-2008 18:00:23
if that axleshaft is red with rust and hasn't moved in eons, you'll never move it.
if they've been stored inside and are not too bad looking, you might get away with it.
Often you'll have to use a 20 ton jack and a chain and a piece of metal to break it free before you move them in. Harder than it looks.
Take lots of PB blaster. You can also take the torch and heat the wedge spline area, and then melt wax in there, it might trickle through voids and provide a lubricant.
PBrowning
04-21-2008 17:57:07
Don't fart around at this stage. Hire a wrecker to do the transport. Given the question you are asking, your Deere knowledge is far too limited for the answers you will receive to this post. Believe me, you will thank me in the long run.
Get your trophy home, and fetch the manuals you will need, then settle in and enjoy the trip! BTW, to learn what manuals Deere has for you, go to the "H Restoration Site (below), and scan across to ARTICLES 1. From the drop-downs, select DEERE PUBS. Page two matches the manuals to each tractor, and at the bottom of page 1 you see how to obtain them. (PatB)
