1946 J D
Ron Cutler
04-21-2008 15:59:39
I just bought 1946 Styled A, nice old tractor.
and Iam checking it all out & ect. Iam rebuilding the Carb. cause it just won"t idle.
Then I find the air cleaner full of water & oil mixed. It set outside before I got it. How do I get the insides of the cleaner out, is it bolted at the top or could it just be rusted?
I got the bowl pieces off. Also it has a small oil & water leak looks like from the gear box & rear end. If i drain it and put in new gear oil ( what weight?) will it be Ok? It stays inside now, it"s only going to go out to show or pull the kids hayride at church from now on.. Thanks
GaryW
04-22-2008 11:37:07
 Re: 1946 J D in reply to Ron Cutler, 04-21-2008 15:59:39
James, nice pics. Background with pine trees looks like east Texas??
GaryW
04-22-2008 13:52:36
 Re: 1946 J D in reply to GaryW, 04-22-2008 11:37:07
Nice country. My roots are planted near Gainesville on a farm in the blackland prarie. Not many trees. You must be over there near Clarksville,Paris DeKalb.
James Howell
04-22-2008 13:27:10
As the old saying goes, "a picture is worth a thousand words". I like to include a picture or two whenever I can.
Yes, large pine trees in NE Texas. There are at least a couple on the farm as wide as back wheel on "Easy".
Also have a couple of 100+ year old black walnut trees at the Ragan house. Ragan house was built in late 1890's.
third party image
My grandfather was a cotton farmer and worked at the cotton gin. All of this farm was planted in cotton up until the mid 1940's.
Had an old-timer stop by this weekend while Nancy and I were putting up fence. He talked about plowing the cotton field with a mule near the Ragan house.
He also talked about my grandfather selling his father property to build the home where he now lives.
Family roots grow deep here in NE Texas.
Thanks for asking.
Mike M
04-22-2008 06:19:57
Air cleaner is to use same weight oil as in your engine. It may be fine with just an oil change ? If you do have to clean it out you have to remove the hood and unbolt it from the cast upper part. I use a hot water pressure washer and degreaser to clean them out.
James Howell
04-21-2008 19:11:58
One of the first things I check on a tractor is the oil cup.
Below is a picture of what I found in my 43B.
third party image
The oil cup on my 46A was dry as a bone; not even a trace of oil or water.
The air cleaner is secured by 4 bolts on the flat top of the air stack.
You will need to remove the hood for easy access to these bolts.
If the oil cup did not have any rusted metal shavings in it, then the wire mesh inside the air cleaner is probably OK.
Since you will be keeping the tractor inside, the oil and water mix will be eliminated.
All you have to worry about now is dirt daubers!
I put an old work sock over the air stack when done for the day.
third party image
Study your operator�s manual on changing the transmission fluid.
Remember there are two drain plugs for the transmission.
Be sure to �flush� it out with 2-3 gallons of high-priced diesel before adding the new fluid.
Here in Texas where it sometimes gets warm, I use 85-140wt in the transmission.
Hope this helps. Enjoy your �new� 46 slant dash A.
third party image
