Anybody have a 422A two-way plow?
jCarroll
04-21-2008 09:25:04
I have a JD 422A plow. It's a single bottom, two-way moldboard plow with 3pt attachment for the 40 or 420 tractors.
As the plow attachment is designed, there are two brackets which fasten to the tractor drawbar which rotate the plow when it is lifted (typically at the end of the furrow). These two brackets are missing with my plow. I intend to make them, so I can operate the plow rotation feature as it was designed.
The rear bracket is mostly a flat bar which the plow bangs against as it is being lifted. If anyone has this part, and can tell me the height of the bar, and it's length - that would be quite helpful. Looking at the OpManual photos, I would judge the bar to be about 2" high, and a foot long.
And, if anybody has the bracket for sale ..... ..... ....
sparepartsTN
04-23-2008 23:32:00
 Re: Anybody have a 422A two-way plow? in reply to jCarroll, 04-21-2008 09:25:04
jcarroll,
I have used it to make a couple of ditches, and did experiment some in a pasture that I"m trying to save. My father bought mine 20 some years ago used and could not get it to work on his Ford, gave it to my sister when she bought a farm in TN. It never was used by her and I inherited it 2 yrs ago, I"m also trying to make it work on my 1962 Ford 4000. The manual was lost while my sister had it and it never had the pieces that you are missing, plus 20 some years of sitting outdoors hasn"t helped it. If I can find some spare time this summer I will try to rebuild the dammaged/missing parts. It pulls easy, I did some 10 inch deep furrows, just need to get the flipper device fixed.
Good luck and have fun,
Warren
sparepartsTN
04-22-2008 12:05:11
jcarroll
I have a 422 plow and a 422A manual. The back bar that you say the plow "bangs against" is simply a device to keep the chain at the same adjustment as the plow is raised. Since the plow is free to move side to side, the chain would miss the end of the drawbar and would not flip the plow. So I would think that you could make the bar any lenth as long as the chain can not slip past the end.
Overly simplified and clear as mud explanation eh?
Anyway I hope it helps, I think the front bracket will be a lot more difficult to make, good luck.
Warren
jCarroll
04-22-2008 18:41:29
 Re: Anybody have a 422A two-way plow? in reply to sparepartsTN, 04-22-2008 12:05:11
Your explanation is perfectly clear. You can tell that I have never hooked this plow to my tractor.
Seems to me that the front bracket can be simplified to whatever it takes to fasten the chain securely, and permit adjustment link-by-link.
I greatly appreciate your response.
Have you ever plowed with yours?
