JD 4000
Russ Crswford
04-21-2008 08:34:19
does this model have a screen on the bottom of tank If so how do I get to it I drained water off the bottom of tank has fuel but not getting to the manuel pump how is the best way to bleed the air after changing filter thanks Russ
M w J
04-21-2008 16:31:09
 Re: JD 4000 in reply to Russ Crswford, 04-21-2008 08:34:19
There is no screen in the tank . The fitting that the fuel line hooks to has a 2 in. long stem that sticks up in the tank so when the tractor runs out of fuel there is a gallon or so left in the tank. You can take the line off of your pump and see if fuel comes out if not blow air in it with the fuel cap off . It may just have a straw or piece of dirt in it . Or you could drain the tank the same place you drain off the water. Mike
