Clutch Disc on JD400
Fred McNeill
04-20-2008 18:05:06
MSM said
I have had several in the shop that the linings have seperated.Some were due to plain old worn out,the others were from improperly adjusted or broken fingers.If not set properly the fingers load a small area of the disc,instead of the whole surface and the lining will lift or split off the backing. Loosing one or 2 of the fingers will do the same thing.
Make sure the fingers are set properly before reassembling the tractor.You need a special tool to do it.
Fred McNeill
04-20-2008 18:06:45
 Re: Clutch Disc on JD400 in reply to Fred McNeill, 04-20-2008 18:05:06
Can the linings be glued back on or do I have to get a new clutch disc?
Also can the clutch be adjusted on the bench i.e can I take the clutch assembly to the dealer to get them to adjust it as I don't have the proper adjustment tool?
Thanks
Fred McNeill
MSM
04-21-2008 02:42:48
 Re: Clutch Disc on JD400 in reply to Fred McNeill, 04-20-2008 18:06:45
Get a new clutch disc.If Deere's is too pricey,there are aftermarket replacements. While you are into the clutch,check the engine clutch also,if it is showing wear replace what is needed,no sense going back into it 3 months from now.A deere dealer can reset the clutch assembly for you. Take the clutch assembly and the flywheel to the dealer.Once the clutch is set,it can be removed from the flywheel in one piece without losing the setting.
Fred McNeill
04-21-2008 07:33:09
 Re: Clutch Disc on JD400 in reply to MSM, 04-21-2008 02:42:48
Thanks for the reply.
Do you know who might carry the aftermarket clutches?
Thanks again.
Fred McNeill
Mike M
04-21-2008 07:35:12
 Re: Clutch Disc on JD400 in reply to Fred McNeill, 04-21-2008 07:33:09
Ask at the parts counter at the Deere dealer. Alot of them can get or even stock some of this stuff aftermarket.
