JD 445 won't start
Todd Treat
04-20-2008 13:52:34
My 445 suddenly quit yesterday and now it won't start. Here is what I know. It has about 375 hrs. It turns over fine and I took the valve cover off and the valves seem to operate correctly so I don't think it is a bad cam gear. I disconnected the pressure side fuel supply from the tank and don't have any fuel pressure. The center light in the dash does not light up when I turn on the key. I also only have the green light on the board on the side of the dash. I also have no spark. Can someone help?
green 5020
04-20-2008 17:54:03
 Re: JD 445 won't start in reply to Todd Treat, 04-20-2008 13:52:34
Check the computer circuit board located below the battery, sometimes battery acid leaks out of the battery and causes everything to quit. You should be able to tell just by a visual inspection if acid has gotten on the board. This is especially true if you don"t have the hose hooked up to the top of the case of the battery.
Todd Treat
04-20-2008 18:15:23
 Re: JD 445 won't start in reply to green 5020, 04-20-2008 17:54:03
What circuit board? The battery is in the front of the 445 with nothing but the front end suspension underneath.
Todd Treat
04-20-2008 15:49:13
Yes, I have checked all the fuses also.
Bob
04-20-2008 14:30:35
Check all the fuses. IIRC, those have an electronic "delay module" that sometimes fails, typically due to moisture and corrosion tearing up the PC board.
