720 diesel won't start
DeereValley
04-20-2008 06:30:25
We got a 720 diesel in that had not run in years. We worked with the fuel system all day and it is now getting fuel. We can tell this by the amount of fumes coming out of the exhaust, if you open it up there will be a lot; and if you close it, there will be little or none. Also, it is starting to slobber. We cleaned the air system. We took the inspection cover off of the block and everything looks good. It still wont start. Anybody have any ideas?
F-I-T
04-20-2008 16:34:49
 Re: 720 diesel won't start in reply to DeereValley, 04-20-2008 06:30:25
Are you cranking or towing it? If you are using the pony or electric starter, how ever equipped, you should really be able to notice if you have adequate compression or not.
How hard is it to crank?
DeereValley
04-20-2008 20:09:00
 Re: 720 diesel won't start in reply to F-I-T, 04-20-2008 16:34:49
We are towing it because it was converted to electric start, but still has some pony stuff on it. The wiring is a mess. We were just trying to get it started to check it out.
We did check the compression release. It is working and releases as it should. The rocker arm clearance is good.
I guess the next step is to pulled the injectors?
Thank you all for the ideas.
buickanddeere
04-21-2008 05:32:27
 Re: 720 diesel won't start in reply to DeereValley, 04-20-2008 20:09:00
I wish all those tinkerers who can"t wait to tear the starting engine off. And do a "quick easy fix" with a 12V truck starter, one wire alternator, a bracket and a 12V battery. These tinkeres sould read and find out just how many of these projects stopped at 1/2 completed in a tangle of wires or just plain failed to work. Starting a 376 two cylinder is no different then starting a 1128 cu"/ 18.5L six cylinder diesel. Walk up to one of those with a 12V Delco 40MT and a group 34 or 31 battery and see what happens. At best the results are having to do a slam start in warm weather, often while getting a boost.
DeereValley
04-21-2008 19:54:57
 Mexican 720 diesel won't start in reply to buickanddeere, 04-21-2008 05:32:27
I guess I should have added that this is a Mexican built 720. It has the 24 volt starter and generator, but I guess they just "touched wires" until it turned over.
Thank you all again for your help.
F-I-T
04-20-2008 20:20:00
If you want a field check on the injectors, you can remove them, then orient the pipes so that the injectors are pointing out where you can see them spray. You know of course not to get any body parts in front of the spray as it can inject fuel under the skin and cause a horrific problem. As you motor it, you should be able to see at least if the injectors are spraying, which will tell you that you are getting fuel and if it is a decent pattern. Anything else, you should take them to a shop, but on the two cylinders, it's always a good idea to have them sync'd on the rack bracket if the they have been dismounted and/or torn down. Otherwise they might not deliver the same amount of fuel at a given rack setting.
wilamayb
04-20-2008 14:56:30
It sure sounds like a stuck valve if you are just pumping fuel straight back out.
RobMD
04-20-2008 09:48:46
Slobber is a sure sign of bad injectors and/or a mal functioning decompression. Not always, though.
Tramway Guy
04-20-2008 06:49:16
Is there a compression release on that beast? If so, maybe it is stuck. I think it holds one of the valves open slightly...if your valves aren"t closing, it will not run.
