mag has weak spark
josh kuhn
04-19-2008 19:59:30
i have a wico c mag on my jd d and has a weak spark (orange) tried a diffrent coil out of another mag still the same have a set of points and condenser coming. if that dont get it hoter were should i start next? thanks
Lee B
04-20-2008 03:55:34
 Re: mag has weak spark in reply to josh kuhn, 04-19-2008 19:59:30
That would be a rebuild by a reputable rebuilder.
As long as the magnet is inside the laminated coil holder it is safe from demagnetization as the laminations act as a "keeper" for it. Once you remove the magnet, it begins to degrade in strength leading to guess what? Weak sparks.
If you've got a re-magnetizer then no problem working on it at home, but I'm fresh out myself. They make a hotter coil you can buy and use but to really take advantage of it you should have it put in by somebody who can zap your magnet back up to full strength.
