830 2cyl axle brgs
mike a
04-19-2008 19:51:02
I want to go through the trans and rear end next month to replace ALL brgs and seals. I have most of the parts all ready,except for gaskets and seals. I have 2 questions: 1.where is the best source for fresh gaskets/seals? I made the mistake of getting NOS from a Deere dealer on their network and they were so old and shriveled up that they are no good. #2 What difficulty can I expect in getting the rear wheels off the axles-this worries me a little.
gtx1967jewison
04-27-2008 20:27:47
 Re: 830 2cyl axle brgs in reply to mike a, 04-19-2008 19:51:02
lots of pb blaster & a couple months of patience is a lot nicer way to remove the hubs. squirt daily. will still need power obviously, but not nearly as much. if a chain & 10 ton ram wont move it, more time & squirt-squirt.
mike a
04-21-2008 15:37:47
toolz; no scoulding from me!!!
Thanks to all you guys for the advice-just hope i don't need that 75 ton press...
2cylinderlp
04-20-2008 07:38:17
I believe this is the thread toolz is referring to:
Link
My 830 hubs were cracked and I wanted to replace them. Apparently there is quite a variation in how hard they can be to remove. When I went to get the axles out of the replacement hubs, using the enerpac portapower set up as I did on the tractor wasn't strong enough. I had to take the hubs with the axles to to a friend who has a 75 ton floor press and that did it. I have a 100 ton cylinder for the enerpac. But I chickened out on use of it because I was afraid of breaking something. Pulling on the hubs through the openings provided was never supposed to involve forces that high. In a floor press the hub could be supported from underneath and therefore much less likely to crack the hubs.
Mike M
04-20-2008 06:44:00
If you get old shriveled up gaskets,as long as they aren't cork type, you can soak them in a pan of water and they will be ok then. Some of these are NLA and all that is let is NOS. You can also buy sheets of material and easily cut your own.You need to watch the thickness on some places.
toolz
04-19-2008 21:42:56
Mike- I just went through this with my 1958 820. Deere had all the seals, and they worked fine. I didn't bother with gaskets- a thin layer of RTV black works real well. Just don't over-do it. My hubs slid right off the axles. There is a thread here somewhere with a horror story about stuck hubs- you might try a search under "830" to find it in the archives. It's good reading with great pictures.
I didn't get in to the transmission, but I did replace one differential side bearing and one axle bearing. The rest were fine, and considering the limited use this tractor will get, it will last the rest of my life.
One problem I ran into was excessive play (in my opinion) in the differential. There are no factory shims for this, and new parts are obsolete, so I made a .080" shim to snug it up. It would probably have been fine, but I wanted it right. My differential shaft is no longer a press-fit, which allows the diff to rotate on the shaft instead of the shaft rotating in it's bearings. I won't admit what I did to correct this cause I'll get yelled at, but it's fixed. I also had to make a few diff end cap shims, since they are no longer available, but it was easy.
Good luck with your project- Kevin
WeirdDeere
04-20-2008 10:42:16
 Re: 830 2cyl axle brgs in reply to toolz, 04-19-2008 21:42:56
Well now I've gotta ask, what did you do to keep the diff from rotating on the shaft? Sometimes you've gotta do what you have to do! I suspect welding?
Brandon
toolz
04-20-2008 18:56:42
 Re: 830 2cyl axle brgs in reply to WeirdDeere, 04-20-2008 10:42:16
Yeah, Brandon- you guessed it- I tacked one of the thrust washers to the side of it's diff side gear. The washer is "D" shaped on the inside, so it will make the shaft rotate with the gear. The shaft will slip in the diff when I turn, but that's better than spinning in it all the time. I expect the welds to eventually break, but the new bearing will get a chance to break in, so maybe it will spin easier than the shaft inside the diff. It's not like I'm farming with this tractor anyway. Shouldn't cause me any problems. Now I'll wait to get scolded.
