Is main case cast on '42 B?
TJC in MN
04-19-2008 18:16:18
Main case cracked just below the bolt hole on the bottom where frame and case connect. (clutch side, lowest outside corner of case near ground).
This is a 1942 JD B, with an angle iron frame, I'm sure the main case is cast iron, though I could be wrong..Any suggestions on how I can repair the small crack would be helpfull, I realize the right thing to do is probably buy a new main case.
Thank You.
M w J
04-20-2008 06:59:54
 Re: Is main case cast on '42 B? in reply to TJC in MN, 04-19-2008 18:16:18
I had a hairline crack about 3 in.long in my G there 10 years ago when I bought it. I scraped all the paint and grease off then cleaned with napatha warmed it to about 150 degrees with a little propane torch and put JB weld on it. Then smoothed it out and painted over it It does not leak yet and my sons use it to pull at tractor pulls. If yours just seeps a little and not a major crack Try it you won't be out anything. Mike
RobMD
04-19-2008 18:46:04
YUPPP... cast.
There are half a BILLION cases laying around salvage yards... literally.
I mean, you could call every vendor in green magazine and they'd have one main case for a '42 B.
Make sure you put your serial number tag on it, if that even makes any difference to you.
