Help JD 2355 wont start
Michael price
04-19-2008 14:52:42
Well the beast started fine and was shut down for about 20min and then wouldnt start. The starter just clicks. I tried to jump it but it just did the same. I dont really know anything about this tractor so hopefully somone here can help. All the cables look fine.
buickanddeere
04-20-2008 11:39:37
 Re: Help JD 2355 wont start in reply to Michael price, 04-19-2008 14:52:42
With this many hours and years. Just get a rebuilt 4KW Bosch starter and install it. It's worn out after 17+ years. The factory starter is likely a warm weather 3KW. Take the step up in power and be glad.
If both batteries are not a matched set of 600CAA with 120 min reserve capacity you are wasting your time. Same age, make and size or they will just fight each other. One battery doesn't have enough power. You can't rely on the skinny sheet metal chassis return from the firewall. Run a real 2/00 cable from the battery (-) bond point at the firewall down to the top stud on the starter mount. Clean the nut and starter casting to bare bright metal.
Michael price
04-20-2008 11:33:25
I took the batteries out and they are on charge. If the gauge on the charger is right they are both dead. If that doesnt fix it Ill look into the ground and then safty switches. I did look at the ground and it looked nice and clean like everything else. I would have took it off and cleaned it anyways but there is a loader on it and its hard to get to.
Michael price
04-21-2008 08:48:02
 Re: Help JD 2355 wont start in reply to Michael price, 04-20-2008 11:33:25
I put in batteries and it did the same thing. I cleaned ground and it didnt help. I got a pry bar one the fly wheel and something let loose and it turned over easy and it started up.
jh
04-20-2008 11:23:50
I had one do like that one time the ground cables are a big thing too mine was ate up but they looked fine wouldnt carry the ground though them an then again it could be the netural safety swtich under the panel where the gear sticks come out hope that helps
Jake Winn
04-19-2008 15:49:11
Could be cables too. Have seen that happen. May not have enough amperage to crank. try jumping from batteries to starter with jumper cables. If not, starter relay is a possibility, then starter.
Roy Suomi
04-19-2008 14:58:21
The cheapest and easiest thing to do is clean the cable connections..At the battery and starter..
