Help! Thrust bearing question!
glsinNY
04-19-2008 14:44:39
I ordered a thrust bearing for my 3020 gas. My JD dealer can no longer get the two piece thrust bearing with the collars which came off it. I order the superceded one with washers. It only has three thrust washers and I am concerned. Instructions say to put top and bottom washer on engine side (rear) and the remaining washer on the front bottom. What about the front top? Should I worry about this? The crank is in good shape and is not being turned. Will this cause a problem with the crank over time??
Thanks! Gordon
Bob
04-19-2008 15:37:54
 Re: Help! Thrust bearing question! in reply to glsinNY, 04-19-2008 14:44:39
The only real thrust is the clutch TO bearing(s) trying to shove the crankshaft FORWARDS.
Should never be much thrust REARWARD, anyhow, so the front washer(s) don't have much to do. Nothing to worry about!
glsinNY
04-19-2008 16:40:01
 Re: Help! Thrust bearing question! in reply to Bob, 04-19-2008 15:37:54
Thanks Bob!
