'44 JD B Front Wheel Spindles
Nate in IL
04-19-2008 07:27:50
Folks-
I had some play in my front wheels (NF) and I opened them up to adjust. I expected a cotter and castle nut. Instead I see an oddball clamp with a bolt in it plus a cotter pin thru the spindle.
Can you give me some info on the why and how to properly adjust. The I&T manual I have doesn't show this arrangement.
Thanks,
Nate
Pappy
04-19-2008 22:17:20
 Re: '44 JD B Front Wheel Spindles in reply to Nate in IL, 04-19-2008 07:27:50
d.coleman has it right. One other thought: Loosen the locking bolt just enough so you can turn the nut with a short wrench. If you loosen the locking bolt too much, the nut will open up and when you tighten it you could slip a thread. Just trying to make 'em last longer.
d. coleman
04-19-2008 15:19:12
this is a standard set up. pull cotter pin, loosen lock bolt. there are more than one cotter pin hole in nut, tighten till good and snug and back off to first hole, install cotter pin and be sure to tighten lock bolt. lock bolt keeps nut tight around axle threads to prevent wear. good luck, d. coleman
Duane Larson
04-19-2008 08:13:08
Nate,
It sounds like your spindle threads have been damaged in the past, and a clever aftermarket device was developed which slips over the threads, and clamps down on the remaining threads to lock the wheel in place. As noted previously, the clamp device is threaded, so loosen the locking bolt a bit and carefully try to tighten the aftermarket device against the wheel bearing. Normally they work great.
greenmech
04-19-2008 07:45:37
The clamp should be threaded. Loosen the bolt and tighten as needed. Then replace the cotter pin. Ron Mn.
