Help Please with no oil pressure
Jackpinesavage
04-19-2008 06:47:00
I need some help and advice on my 1952 JD Model B that I use for snow removal and landscaping chores. Started it yesterday and the oil pressure gauge showed no pressure and the engine seemed to be noisier than usual. I shut down immediately, removed the inspection plate that sits over the crankshaft and can see that the coupler is intact on the oil pump shaft. I turned over the engine and the pump shaft rotates freely. I started the engine for just a couple of seconds and got good oil spray to the crank. I know the basics of the engine but am surely no expert. I am wondering if it is as simple as a bad pressure gauge or if there is a deeper problem that I should look for. Thanks for any help.
johns48jdb
04-19-2008 17:44:09
 Re: Help Please with no oil pressure in reply to Jackpinesavage, 04-19-2008 06:47:00
msd, sounds like you have water mixing in your oil. are you losing coolant? leave the oil out and the drain plug removed over night and see if any moisture comes out the drain hole. driving the tractor until it gets hot for a while may help get rid of the water from condensation.
DanL-Colorado B36320
04-19-2008 13:16:00
On my 37, I tried a new gauge and it didn't help. However, if I unscrewed the gauge with the engine idling, oil went EVERYWHERE from the open hole. So I knew the pump was turning.
Turns out, one of the compression fittings (on one of the large oil lines on the filter outlet) was loose; the nut had completely backed off and had slid down to the other end of the line. I reset and tightened the nut and the OP came right up where it belonged.
Good luck. Hope it's something simple.
Jackpinesavage
04-19-2008 09:10:54
Thanks for the quick replies.
I changed the oil and filter in late Nov. and had only run the tractor for a few hours since then. The pressure loss was sudden... last time I used it there was no problem. Piece of crud getting in the wrong place sounds entirely possible.
Grabatire
04-19-2008 08:59:27
I suggest you try another gauge. It may save you a lot of work.
If you are getting what you refer to as "good spray to the crank" it indicates the oil pump is delivering oil. However, there still could be a minor blockage in the oil pump intake or, there may be some crud in the pressure relief valve.
I had the crud-in-the-relief-valve problem with a Model D. It looked like a small piece of gasket material. How it got there is anyones quess, but when I cleaned it out, the pressure came back.
RobMD
04-19-2008 07:51:37
Is there sludge in the bottom of the crankcase? How about that oil filter, if it hasn't been changed in eons, it might have chunks in it.
If the above has been covered already, has this been a problem that happened instantly or one that was gradual?
YOu can try loosening up the adjusting nut and screwing the adjuster in to get more pressure. should take about 1-2 turns, you have to play with it.
MSD
04-19-2008 09:02:23
 Re: Help Please with no oil pressure in reply to RobMD, 04-19-2008 07:51:37
I had an H JD that I overhauled and it sat in the shed for 5 or 6 years. When I went to start it last fall to get it painted, it had no oil pressure. The oil had turned to a dirty sludge that completely blocked the filter. I had to drain the oil, put in a new filter and wash the crankcase out to get it clean again. Was really slimy stuff to get out too.
