Soundguard Cab Interior Kit Cleanup For New Kit
John in Md.
04-18-2008 10:15:04
I pulled the old foam out and I want to cleanup the surfaces before I apply new adhesive. How clean does it have to be and what should I use to clean it? I don't want to use something that will leave a film that keeps the adhesive from sticking (had that happen the last time).
Thanks, John in Md
msb
04-18-2008 20:10:06
 Re: Soundguard Cab Interior Kit Cleanup For New Kit in reply to John in Md., 04-18-2008 10:15:04
NAPA some auto trim adhesive remover that works a lot better than a scraper or a wire wheel cup.Either are good for starters though.
mattd
04-18-2008 18:00:05
i usually use a sharp gasket scraper or knife to scrape the loose foam off. a strong brake cleaner or even either will work. you are using the 3m spray adhesive arent you?
John in Md.
04-18-2008 18:10:21
 Re: Soundguard Cab Interior Kit Cleanup For New Kit in reply to mattd, 04-18-2008 18:00:05
I'm using 3m Super 77.
