'36 B break in
Kris A NC
04-17-2008 17:21:35
I will have my '36 B back together shortly after a sleeve job, new rings and a valve job. I do not have access to a field to plow or belt work or PTO work and I do not have access to a dyno, that I know of. I was wondering about the best way to break it in in my situation. In my neighbor hood I have some slight inclines. I was thinking of hooking my utility trailer to the back and towing my JD L110 lawn mower around a while. Does anyone else have any suggestions and proper protocol and procedures, do's and don'ts? I appreciate it!
Kris A NC
F-I-T
04-18-2008 05:44:14
 Re: '36 B break in in reply to Kris A NC, 04-17-2008 17:21:35
Any place nearby that you could tow something like a large log around? By changing gears you change the loading. A nice little log in 1st for a while, then 2nd....a log can be a nice load.
jdal
04-17-2008 18:25:13
Kris
You should work it a little harder. If you can hook it to a pickup (chain through a pipe to keep from having slack followed by a jerk) and have someone that can apply the breaks off and on. Start with light resistance on and off then build up to where she has to really work. Just like exercise - build up and cool down.
Good luck JD AL also NC
jd b puller
04-17-2008 17:45:04
 Re: '36 B break in in reply to johns48jdb, 04-17-2008 17:21:35
Kris A NC said: (quoted from post at 21:21:35 04/17/08) I will have my '36 B back together shortly after a sleeve job, new rings and a valve job. I do not have access to a field to plow or belt work or PTO work and I do not have access to a dyno, that I know of. I was wondering about the best way to break it in in my situation. In my neighbor hood I have some slight inclines. I was thinking of hooking my utility trailer to the back and towing my JD L110 lawn mower around a while. Does anyone else have any suggestions and proper protocol and procedures, do's and don'ts? I appreciate it!
Kris A NC
Feels good to FINALLY get it together doesn't it? I doubt that little load would do much to break it in. Try pulling a smalll pickup truck with it as fast as it will let you. you could always take it to the tractor pull. There's one in Edmond, SC and Bethune, SC this weekend. Sure you'll get killed, but as long as you don't go there with hopes of winning, you'll have a good time and get to show off your hard work.
Kris A NC
04-17-2008 19:22:57
 Re: '36 B break in in reply to jd b puller, 04-17-2008 17:45:04
It sure does feel good. I won't have it together for this weekend, but hopefully next. My clubs show is on the 10th of May in Oakboro close to the house. I may have to enter just to give her some exercise. I appreciate the comments and insight. I guess I could also let her pull my Dodge 2500...I know you said small, but thats what I got...I guess I will figure it out. Thanks again!
Kris A NC
