4020 shifterlinkage adjustment
dale krueger
04-17-2008 15:12:09
i have 4020 that i have trouble shifting in to high range it goes into 1246 and reverse fine but it does not gointo 3578 very good, ive had the shifter rebuild and replaced all the linkage for the range shifter
Resting Relics 1
04-18-2008 06:24:30
 Re: 4020 shifterlinkage adjustment in reply to dale krueger, 04-17-2008 15:12:09
Dale, I've got to agree with Ed. Sounds like a problem with the high range sycronizer pack. As long as the shifter lines up with the neutral position there isn't much more to do on the outside. May have to pull cover and take a look. Not unusual to have these packs go back. If it's bad you'll have to split the tractor to get the top shaft out. John
Edpap
04-18-2008 05:43:04
Hello, I am assuming this is a syncro range trans ?
you might have something going on with the synchronizer or the shift plates inside the trans. the gears you discribing use two diferent shift forks. I would un hook your lincage and try to shift it by hand if you can't. you can pull the top cover of trans and take a look. if i remember right it is not too hard to get the cover off. it has been a while since I did a 4020 trans. I think you can change the shift forks and shift plates with out spliting the tractor be sure to get an IT manual before trying to remove the shift forks you can get into trouble with synchronizers when you pull the shift fork If this is a power shift trans then that is a whole different ball game.
good luck ED
Handsome Jim
04-26-2008 15:48:02
 Re: 4020 shifterlinkage adjustment in reply to Edpap, 04-18-2008 05:43:04
i'dbe
Handsome Jim
04-26-2008 15:48:01
i'dbe
Handsome Jim
04-26-2008 15:47:56
i'dbe
