620 throttle problem
m-mcoloma
04-17-2008 10:40:15
How do you adjust the throttle lever on a 620? Mine will not stay open. It keeps droping back from full throttle to about half open. Have to run with your hand holding the lever farward.
BobinKS
04-17-2008 18:51:01
 Re: 620 throttle problem in reply to m-mcoloma, 04-17-2008 10:40:15
My grandfather-in-law had me hop down grab a handful of dirt and toss in around where the hood is cut for the throttle lever. It worked fairly well, when I went to replace the facing I found a very flat and almost silky smooth piece of burlap bag that had been used in between the facings to tighten it up.
F-I-T
04-17-2008 11:32:49
It's either the simple, "tighten the nut on the center stud with the spring to increase spring pressure on the two internal disks" fix, or the "the two disks are worn out and need replaced" fix.
You can download a parts book .pdf file at JDPARTS which will show the mechanism, and the adjustment is pretty much self-evident. If the nut bottoms out, then you'll need to refresh the disks. You can either replace them, which can be pricey, or use some other material, from glued on 120 SC bonded abrasive cloth, to the palm of a leather glove, to two roughed up brass disks.
Or, use what our neighbor used for a season before he asked me about it and I fixed it for him. A piece of inner tube cut as a rubber band and hooked on when you needed to have WOT. Today I guess he would have used a bungee cord for that "modern" look.
Take a look at the archives for a lot of other ideas.
