4020 Hydraulic Leak around Pump Area
Gentlemen Farme
04-16-2008 19:31:09
I removed the hydraulic pump from my father's early model 4020 gas tricylce front end tractor this past weekend (the previous posts were very helpful). After removing the pump along with pounds of oil soaked Indiana topsoil we performed a major cleanup and thorough inspection of the pump. From inspection it does not appear that the leak originated from the shaft seal (there is no detectable play in the shaft) piston caps or high pressure lines. I have not ruled out the fill line from the cooler but it doesn't seem to be the source. I crawled back under the tractor and found a curious line from the steering motor to the oil cooler. Said line did not appear to be a factory original. It was made up of three pieces of hose, a section of metal tubing numerous clamps and a tubing fitting screwed into the steering motor that was loose and had no flange on the end. I have looked at parts diagrams but am unsure of this lines purpose. My best guess is that is part #R33733 which is listed as the steering motor vent to cooler hose. I could not find a part for the tubing portion that screws into the motor. Could this be the hydraulic oil leak source? Should we fix the line cleanup the remainder and reinstall? Hate to crack open a pump that appears ok.
Edpap
04-16-2008 20:26:25
 Re: 4020 Hydraulic Leak around Pump Area in reply to Gentlemen Farmer, 04-16-2008 19:31:09
There should be a case drain line from the pump it is a small 1/4" or so line that has to go to low pressure oil, some go up to the cooler or back to the trans. the fitting on the pump is just a small hose barb it should be in the front housing of the pump.it is a blead line for the front bearing. some pumps will leak all the time and some won't.
Hope this helps Ed
Bob
04-16-2008 19:57:08
Here's the steering motor end:
Third Party Image
#7 R33732 OIL TUBE
#8 R28676 TUBE NUT
#9 R28677 SLEEVE
The line is somewhat loose in the motor/fitting, and is sealed by a rubber sleeve, Key # 9.
Too bad you couldn't get it more cleaned up and would have run it, to see for sure what is leaking BEFORE you tore it down!
