JD 4230 STARTER TROUBLE
COLLIER FARMS
04-16-2008 19:02:15
Is there a replacement starter for the original delco starter? I am having a lot of trouble out of the delco starter. THANKS
mikeal
04-18-2008 16:56:38
 Re: JD 4230 STARTER TROUBLE in reply to COLLIER FARMS, 04-16-2008 19:02:15
I have starters for your tractor, brand new gear reduction, 816-586-2841 thank you
Texasmark
04-17-2008 15:47:32
 Re: Let's back the truck up in reply to COLLIER FARMS, 04-16-2008 19:02:15
What kind of problem are you having?
What makes you think the problem is the starter?
Having the same critter, the first thing I noticed that absolutely SUCKED was mother benevelont deere in all her green glorious magesty stuck 2ea 6 volt batteries in series. The most stupid application of electrical engineering principles I can think of.
Answer my questions and I'll tell you the rest of the story if you are interested..... you need to be.
Mark
COLLIER FARMS
04-18-2008 04:01:46
 Re: Let's back the truck up in reply to Texasmark, 04-17-2008 15:47:32
Its a delco.
WTW
04-17-2008 07:12:05
Good advice as far as using the NipponDenso starter as it is twice the quality the Delco ever was new. The concern I have You may have more problems than just your starter causing this condition. If I was you I would locate the high pressure hydraulic line coming from main hydraulic pump. The line has a coupling just under and behind the right hand battery box. it will take two 1" wrenches to disconnect and cap this line. Try starting tractor with this line capped off. If tractor starts noticeably better or easier this test will indicate that you have a high pressure leak in the hydraulic circuitry that is causing pump to feed leak causing increased pump load on your starting system. This leak could be anywhere in the hydraulic system from hitch valve, SCV's to steering or brake valves. Most likely in the hitch or SCV valves. This can be isolated and found by simply capping off individual valves until you find it. Another way to find internal leaks is start tractor cold and do not move or use any function on tractor, rather let it sit and run (may take 30 minutes to an hour) while you feel valve housings for heat which is created by leak restrictions. If you have a valve getting warm and nothing is being used you have a high pressure leak to return or sump. Not that uncommon with these older closed center systems. Fix your problem not just your damage. Good Luck, DW
COLLIER FARMS
04-17-2008 09:01:46
 Re: JD 4230 STARTER TROUBLE in reply to WTW, 04-17-2008 07:12:05
Thanks for the info.
mjbrown
04-17-2008 05:38:44
Agree with the Nippondenso replacement. It cured my 4230 but it's expensive.
COLLIER FARMS
04-17-2008 05:57:30
 Re: JD 4230 STARTER TROUBLE in reply to mjbrown, 04-17-2008 05:38:44
What are we talking about two to three hundred dollars or more?
mjbrown
04-17-2008 08:33:50
 Re: JD 4230 STARTER TROUBLE in reply to COLLIER FARMS, 04-17-2008 05:57:30
More than three hundred for mine if I remember right. That was four or five years ago.
Wilamayb
04-16-2008 19:16:04
Yes, the NIPPONDENSO starter is a great replacement, and will be sold by your local Deere dealer, however it is likely that the Delco can be referbished by a local starter/alternator repair shop for less dollars.
COLLIER FARMS
04-17-2008 05:11:18
 Re: JD 4230 STARTER TROUBLE in reply to Wilamayb, 04-16-2008 19:16:04
Allready done that 3 or 4 times. THANKS
