730D Transmission Gears
Gpower
04-16-2008 14:40:44
Looking for F2624R Input shaft w/gear, F2619R gear, F2610R gear and F2603R nut, the nut goes on the bottom transmission shaft on the outside. None of these are available through JD, nor on the locator searches. Have called some junk yards, and they want 750.00 for the 3 gears and they are not in the best shape. Are there any aftermarket gears out there?
Mike M
04-17-2008 04:42:31
 Re: 730D Transmission Gears in reply to Gpower, 04-16-2008 14:40:44
There are some aftermarket gears out there for certain ones. I have used them in the past with good results.
Wilamayb
04-17-2008 04:09:36
Price it with these guys.
Carl Mitchell and Son (800)467-8907
Everything I purchased was farily inexpensive.
I was at their yard on Monday. They had two 720's with 1st over reverse and one 730 with 2nd over reverse.
I dont have time now to look through the parts catalog, but if you are 2nd over reverse they may or may not be the same gears, depending on optional speeds. If you are 1st over reverse you have nothing to fear.
Kent Petersen
04-17-2008 04:31:58
 Re: 730D Transmission Gears in reply to Wilamayb, 04-17-2008 04:09:36
try Artichoke Lake Tractor Pasts i got a F2610 there for $40.00 1 320 596 2208
