JD 4000 Steering
RCTN
04-15-2008 18:26:28
I just swaped my roll a matic front back to a wide front and the steering doesn't seem as responsive as it used to. The ROM was on the tractor for about 5 years and I never noticed any problem. I have changed all HYD filters and fluid and cleaned the screen. It seems a little harder to steer to the left than to the right. It still steers OK but not the one finger steering that I seemed to remember from before. Thanks for your help!
DaveH IA
04-16-2008 07:52:08
 Re: JD 4000 Steering in reply to RCTN, 04-15-2008 18:26:28
Back off the bolts that hold the steering arms on the spindals if the arms are worn they can drag or lock-up the steering Somthing to try
RCTN
04-16-2008 18:07:22
 Re: JD 4000 Steering in reply to DaveH IA, 04-16-2008 07:52:08
I used new steering arms, infact, everything is new on the front end except the center tube. Thanks for the reply tho.
Iowa Ron
04-16-2008 07:04:22
HAD A 4010 installed a loader and a wide front ,the tractor the wide front came off of drove perfectly ,but on the 4010 coulld not drive wot in 8 th gear on the road.put the rollar matic back on the 4010 ,and drive perfect
RCTN
04-16-2008 00:21:50
I used the same bolts that came out of the wide front orig., but I will recheck. I rebuilt the wide front, all new knees, spindles, bushigs and soforth. Thanks for your help.
jd-tom
04-15-2008 20:02:02
Did you use the correct length bolts to mount the wide front on the tractor? If you use bolts that are even a little too long you can get them tight but they stick thru the mounting plate on the power steering unit under the tractor and bind on the other side of the mounting plate against the steering unit. If you leave it like this it will damage the steering unit. The parts catalog for this tractor calls for a 2-1/8" long bolt. Also, if you are used to how the tractor steered with the Roll-O-Matic it will seem a bit more sluggish with a wide front axle.
